Viore PD50VH80 50" Plasma`
    Re: Viore PD50VH80 50" Plasma`
    So, have you tried tweaking VSC and VE?
    • kevinm34232
      • May 2012
      • 1884
      I lowered Vs and Ve by 2-3 volts and it seems to be OK now
        Check for pink maldischarge on full white pattern after dropping Vs.
        • kevinm34232
          • May 2012
          • 1884
          Looks good so far, boot up screen is all white with Viore logo.. There is still a slight amount of lighted pixels when changed from a still image to black screen. Should I drop Ve a little more?
            Try playing a little more with Vsc.
            • kevinm34232
              • May 2012
              • 1884
              I just dropped Vsc also by 2V and it looks good. It's hard to tell right away it doesn't happen everytime but is 100% better than yesterday.. Thanks!
              • Uzer
                • Jun 2020
                • Восточный Казах&
                #67
                Hello! I have the same TV with the same problem, but not quite like that, when I turn on the TV, the relay goes off to protect it, it doesn't work, but if the unit is installed, the relay works, what's the matter? Maybe it's sitting somewhere and turns off the red indicator 5 times, which voltage isn't goes because short circuit voltage is not measured.
                • orko76
                  • Jul 2023
                  • Mexico
                  #68
                  hello would anyone be so kind to tell me the v and uf for the capacitor marked in blue with an X thought it was 160v 33uf
                  • KYBOSH
                    VIORE PDP4210EA Plasma TV 42 inch - No Video on DVI
                    by KYBOSH
                    Got my hands on an relatively unknown TV brand about two weeks ago.
                    I certainly hadn't heard of it before.
                    Previous owner didn't give a description of what was wrong and when I got it the back cover was already off.
                    I put it on the back burner until I had so spare time to look it over.
                    Today was that day.
                    I plugged it in and was surprised to see that it started up without any issues.
                    This is an older TV and the most modern video input that it has is DVI.
                    I was scrambling to find a DVI connector or adapter as I haven't fooled with that...
                    01-27-2023, 08:19 PM
                  • ArMaaN376
                    Samsung PS51E550 Plasma TV
                    by ArMaaN376
                    I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                    Opened TV cover & observed foll
                    a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                    b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                    c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                    How to confirm Y -Buffer board...
                    06-19-2024, 04:05 AM
                  • jm1234
                    Panasonic plasma TX-P42ST50 - 6 blinks
                    by jm1234
                    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                    I checked that board for any obvious faults...
                    05-22-2024, 06:59 AM
                  • KYBOSH
                    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                    by KYBOSH
                    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                    No picture but you hear the TV static (white noise) playing loud and clear.
                    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                    But it seems they didn't get too far and just left it.
                    When I first took a look I was amazed at how pristine the inside looked.
                    Its as if the TV had been in a time capsule.
                    Caps looked like they were just pulled off the self.
                    Copper coils had no sign of corrosion on...
                    02-01-2023, 11:10 PM
                  • alltvrepairs
                    Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                    by alltvrepairs
                    I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                    I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                    Any one met this problem in the past?...
                    10-08-2025, 07:34 AM
